Re: Dixell Controller Parameters
Go to www.dixell.com , register and download the papers you need
I've already done that before posting, But I can't find the info for this particular model. I found a similar model, which has some of the same parameters.
I just looked again, just to be sure, and managed to find a list of all the parameters, but It's in Italian and doesn't give a detailed description of what each one does. For example, most of the parameters are just numbers but some are letters or codes, so I can't work it out without knowing exactly what they mean.
you make me go down to van........
I will get them for you
1 Attachment(s)
You got the parameters wrong,
Here is the page scanned
Good luck
Did a quick check on Dixell site and yes the first download of the XR20C parameter list was in Italian. So I clicked the 'English' flag and got the English version.
It didn't have example settings though, just the descriptions of the parameters.
Re: Dix ell Controller Parameters
Following on from everyone else's help and advise.
I have posted these pages.
Hopefully they are of use.
As they are slightly different from chemi-cool's
Cheers Grizzly
See how easy this an be Airefresco.
The magic word for this is Google:D
Thanks for the info, that is exactly what I needed.
If I click on that English flag, then the page goes back to the start. Anyway, doesnīt matter now, because the one Grizzy posted will suffice. The one Chemi posted, I donīt think thereīs enough parameters on that, but ill take to site anyway, just in case.
Thanks Again
The saga continues,
Went back to site on Friday with the codes that were posted. Apologies to Chemi, because the list you gave was actually very usefull. I went through the codes and there are still 17 codes that are not in either of the 2 manuals posted. All the other codes are now set to factory defaults, while I try and get the thing to work. At the minute it just flashes the compressor light.
I was thinking that maybe there is some kind of hidden menu or something that gives you access to some new codes? Would anybody know anything about this.
Another thing is that the rEL value is 3. This i assume is the software version, which I believe should be 4. Does this make a difference?
Iīve updated the first post with the codes that are on the controller but not on either of the 2 lists I now have. If anyone could share some light on these, I would be very grateful, as I donīt really want to replace a controller just for a couple of codes been set wrong.
In any of the manuals does it tell you how to reset to factory settings?
I wouldnt have thought a bottle cooler needed any special setup.Just set the setpoint and away you go.
Have a look at this pdf file originally posted by Brian_uk many moons ago:p
http://dixell.com/linea58/download/XW271L_E.PDF
It shows a few of the parameters that you are missing.Hope it helps.Its for an XR20 controller.
Funny\strange how all the parameters aren't the same yet they are for the same controller.....
Cheers, Iīm sure iīll be able to get all the codes now with all the info posted.
iīve only had a quick look through the manual Nike123 posted (Thanks BTW) but the 40C and 60C look like what I have, so Iīm thinking maybe someone has updated the controller with the wrong software.
anyway, cheers again
Even if someone should have updated with new software - I don't see how this can be done by a 'normal' user - the parameters stays the same, only some are added.
I've looked at the manual properly now and gone through every model to find this missing codes. I am only short of 7 codes, but there is a code that gives you factory defaults of all the parameters, so i'm going to try this. Hopefully that will do the trick and I can just leave the ones I don't know at the factory default value.
I've changed my mind now on someone changing the software, because there doesn't seem to be model with the exact same parameters.
Replace the controler for the sake of Ģ70 is it worth all your efforts;)
Dear airefresco.
please go to the second level of the parameters in the document and u will find what u need.
best regard.
I know this is a little and a little too late but, I am the distributor for Dixell in North and South America. Any time the list of parameters has added options, i.e.; parameters that cannot be found on any parameter sheet the control has become inoperable. One of the indications as to a short caused by water is if the control shows 31 degrees F or C constantly... Also if you request to be contacted Dixell will proptly have some contact you generaly in less that 24 hours...
