McQuay HSA Screw Compressor
Hi Guys,
Anyone got a maintenance manual for a McQuay HSA205QL27YB screw compressor?
It's installed on an ALS E.
I think that the oil level on the separator should be somewhere in the top sightglass but just wanted to double check.....
Cheers,
Bash
Re: McQuay HSA Screw Compressor
Hi you got frame 4 compressor with separate oil separator, the oil level should be above the bottom sight glass and below the top,
There is no maintenance manual for the compressor, any compressor problems let me know and if I can help, i will
Cheers Ghaz. These bad boys aren't in great shape. Just taken them on and 4 of 4 circuits have piled in..... leaks, soft starters, no oil and potentially knackered comp on the list. Perfect way to spend bank hols!
