Re: YORK YSCACAS2 style C
it would seem the vsd you have has a power supply problem .
check all the flat cables and connections
when replacing the main card the clock will need to be reset .
this seems like a very vague fault message!!
good luck
Check the electronic protection of the compressor motor, it is connected in series to the coil of the power contactors and causes alarm of missed departure.
no vsd
electromecanique starter
check your contacs that feed back an input to the controller on contactors status.
i would also heck your relay board.
good luck
goshen:
I changed the following parts:
relay board
power supply
diode rectifier
digital input
CM2
the RTC would have some relation with this problem?
