Daewoo FRSU20DAI side by side fridge freezer Beeping - Error C1 AND F3
I have a Daewoo FRSU20DAI side by side fridge freezer and since the moment you turn it on, it will beep every second.
When you check the error i can see C1 and F3
Sometimes the F3 goes away but the C1 always stays.
The symptoms are that sometime during one of its cycles, it will stop cooling.
I have checked the manual online and i cant seem to understand the error codes.
What can be the issue.
Can anybody help?
Any suggestions are most appreciated.
The link for the manual can be found below
http://www.fridge-manual.com/manuals...oo_FRS-U20.pdf
Thank You
Re: Daewoo FRSU20DAI side by side fridge freezer Beeping - Error C1 AND F3
“F3” error
Cause : in case defrosting return is done by time limit of 80 min
Check point : Measure the resistance between both terminals of the defrost heater.
(Assembled with evaporator)
If the resistance is ∞Ω (disconnected) or 0Ω (short) change the
“C1” error
Cause : in case comp. works for over 3 hours when D-sensor temp. is over -5℃
Check point : Refrigerant leakage
Thank you for your reply.
I already read that information from the manual but it seems to cut off about the F3 error.
It says
"If the resistance is ∞Ω (disconnected) or 0Ω (short) change the "
Change the what? It seems they missed a word out.
Also can this be the reason why the fridge is beeping every second?
check the resistance of the sensor- unplug it off the pcb- best way is to have the fridge freezer switched off for a day and check all the sensor values are similar as theyre at te same temperature
it does say if the cooling operation is too long then possibly short of gas
a quick way of identifying this is if the compressor body is hot- checkthe condenser coil at the back is clear- a can of compressed air will clear dust build up
Thank you for your response.
I will give this a try and report back.
Many Thanks
