Eliwell id974 with lost password and locked keyboard
hello every body,
I have a freezer with Eliwell id974 temperature controller, It was locked ,so i can't change parameters because the password was lost,
how can i open the program ?
Re: Eliwell id974 with lost password and locked keyboard
You need copy card or Elliwell software and interface. Copy card is programed by other free instrument or by Elliwell software and interface, and than copied to your protected instrument by copy card or by computer and interface.
Thank you nike123,
Good idea;
But how can i get Elliwell software and interface or Copy card?
Order from Elliwell (Invensys)
http://tinyurl.com/ypg5yv
abd.koj
hello every body,
ABD Please open the attached pdf.
It explains how to lock and unlock the keyboard.
Also there is a section about the program passwords etc.
Open the attached and all will be revealed
If you are in a hurry, replace the controller
Chemi:)
Please send to me also, thank you.
Martin Smanka
Martin check the attached on my post above.
Thank you, but how can i open the menu, when i don't know the password? It is possible? Some universal password or something else?
change the controller, 10 minute job.:Dby the time you have done messing about with it may end up cheaper.;)
Martin Smanka
Read it!
It tells you how to access the relevant section and the required password.
Hi Martin, your JDK Nymburk, will help you :)
Read it!
Hey Martin.
Misread what I posred myself.
Check out Josef's reply.
I will try and post more tonight.
When back from Work.
Grizzly, password I go to another forum, but not confirmed, and answers a few members :mad:
To unlock and reset an ID974:
1)Push and hold the set key
2) When PA1 shows scroll to 135 which is the master password
3) Then enter DIS folder and then sub folder PA1
4) Enter your new password ( make a note of it) and then push set
5) If you want to unlock the keypad ...still in the DIS folder scroll to sub folder LOC and set to n.
That should do the trick.... I know this works as I had to carry out this procedure yesterday.
Good luck!!
Password 135 opens device id 974
this is a top secret but the over riding password on th id range is.........135 dont tell any one:)
