Re: Motor bearing failure
Thanks for sharing.
Do the people in charge of the cost cutting get a pay rise because of the costs they have cut?
HVACRsaurus
Thanks for sharing.
Of course they do!
Engineers plan for the future, Others plan for now!
Glenn now is the time to ask for a stand-bye pump and who ever says no,
Ask them to confirm in writing that you are not authorised to get one.
After that you are covered. its a brave or stupid fellow that signs your disclaimer.
On one of our site facilities and property managers get bonusses for cutting costs. thats how difficult it is engineers to plan.
Pump motor sat for a year and lubricant moved down from the upper side of bearings, leaving a good portion of the bearing dry and exposed to moisture and surface rust. Most likely some lubricant leaked out.
Initial spin up of your motor left the bearings chewing on a combination of excess friction and heat, metal fragments and diluted lubricant.....I guess you figured that much anyway :)
Interesting reading so thanks for sharing.
