:D Hey guys, any of you got the yellow jacket system analyser 40812 ? I would like to have some feedback on it before buying, is it worth it ? I find it interresting for all it does but sure would appreciate some pro's input!!
Thanks guys !!!
Thanks guys !!!
Hi Lancelot,
As I've read here and elsewhere, YJ appear to have some technical and /or marketing collaboration with a product called Digicool from Canada or US. Got a lot of good write -ups.
I expect someone here will respond or put you in touch with them.
regards
TP
THanks for your reply there Absolute-zero,wich model of digi cool are you using and since when ? Is it worth it ? because my boss says it's a little expensive but if it does the job he don't mind buying it!!!Thanks again man and take care
The quotation that says "Nobody ever regreted buying quality" is definately true of Digi-cool. The "1250" is the way to go, best decision you will ever make.
If you need to take a lower spec the "1600" could be the one. Do a search, they have an on-line store.
I bought the yellow jacket digital analyzer late last year.
The only problem i had was to take SH and SC measurements the probe had to be swapped from pipe to pipe as there was only 1 probe.
After looking on the net i found that Digicool had brought out the DRSA1250 which had 2 probes built in so i upgraded my software ( Yellow jacket ones and the Digicool ones were the same) so for all intents and purposes i now own a set of Digicool DRSA 1250 and can throughly reccomend them.
