rebellad
Thanks for this guys, managed to get it up and going again with your help. Another question for you though!! My water tepmerature at the indoor unit is up around 30 degrees but when I check the temp at the manifold it is down around 21-22 at the flow and around 19 at the return, should the temperature at the flow at the manifold be the same as the one at the indoor unit. The pipe coming into the indoor unit from the outdoor unit is always alot warmer than the one coming out to the manifold.
