1 Attachment(s)
Daikin Capacity Adaptor - resistor Equivalents - To Remove PJ/AJ Fault Code
As I could not find a list of adaptor resistances here is a table of what I have found from hunting around online. Enjoy and use at your own peril!
If you have more info or can help to improve the accuracy it would be much appreciated. The idea is to help people save time and the cost of an adaptor (about 6 pounds) by using a resistor costing about 19p from Maplin and a suitable connector or converting an old adaptor. These are needed to clear a PJ/AJ fault code usually after a pcb has been replaced.
