back2space
Have you made sure that side to side airflow is not coming into contact with the breakfast bar so as not to push air back down into the unit too soon. Have airflow pointing up at ceiling level and the side to side airflow vanes pointing straight ahead.
What fan speeds are you using & is the room temperature suitable even though it is cycling off sooner?
If so then try running the fan at a lower speed along with the above comments I mentioned and see if that increases the cycle on time.
