Copeland ZRD-81 noise issue during modulation
I have a problem with compressor ZRD81. AC unit is equipped with one compressor and during PWM modulation, when pressure LP and HP are almost same - appears strange noise (check link below):
https://drive.google.com/file/d/18Nh...ew?usp=sharing
Any ideas what is going on?
Re: Copeland ZRD-81 noise issue during modulation
Can't get the audio to work, maybe there is not enough pressure differential to hold the scrolls together as designed at low load. The digital scrolls (not sure if that what you have) do growl a bit when unloading and loading.
Partykus
when pressure LP and HP are the same
When the system is off and pressures are equalised then this statement could be true but I struggle to imagine a running system with equal pressures?
compressor running the wrong way ?
Some times just before pressure equalized, scroll is turning backwards .
To avoid it' a NRV should be installed on the discharge line.
Most scrolls has this chek valve
sounds like gas pulsing through a valve
