5 Attachment(s)
help me .. how I added oil to compressor for centrifugal chilled water
Dear brothers .. help me how to add oil and which lubricate the parts of Eombrisr when you start chiller type (liters) compressor centrifuges(trane), because the index of oil are very few, and there are traces of loss oil on pump, and we have to address exuding, but I don't know from anywhere added oil, Attach your photo and special pump oil in trane chilled water .so I hope the people of experience help me to know the place for adding oil, as exists with pictures attached and the possibility Tachireha Aalsourh Thank you very much
Re: help me .. how I added oil to compressor for centrifugal chilled water
The 3/8" connection on the shut off valve under electrics box looks good. Do you have an oil pump? If so pump it in there. If not shut the compressor off, pull into a vacuum and suck it in there.
thanks dear Newmanref ....
Is is possible to place marking Add oil .. inecate on photo plz
NewmanRef
how I can Open the oil charging valve on
the bottom of the oil tank of
the CVGF and operate the oil
recovery and recharge unit oil
pump to charge the oil into
the tank.
.... can u indecate that on photo plz
install monkey
the tank.
1 Attachment(s)
u might need to zoom on the pic
Attachment 11437
