pressure drop between expansion valve and distributor
Hello,
In a heat pump system termostatic expansion valf and distributor with capilary tube have totally 13 unit PD. I want to ask, in this kind of system , If the pressure drop of distributor with capilary tubes is higher than expansion valve (5unit from expansion valve, 8unit from distributor) , what kind of problem can be occurred ?, how can I solve this problem? For example, do I have to change distributor or capilary tube design ? And what is the reason of these problem?
I hope I explain my questions enough...
I am looking forward to hearing your opinions…
