Hi brothers,
Would you kindly provide Stal S83 & S26 swept volume .
Both motor's spec are 3 phase 380V 60HZ, compressors max speed are 4000 rpm .
Thanks a lot!
Best regards
Hi brothers,
Thanks a lot!
Best regards
Hi, Jeter Lin :)
STAL-MIMI MkII - S26
at 50 Hz 700 m3/h max shaft input power 250 kW
at 60 Hz 840 m3/h max shaft input power 300 kW
Hope this will be of some help to you.
I believe if you search RE forums you can find some capacity data regarding STAL S-83
Best regards, Josip :)
