Re: Reclaiming refrigerant
http://www.sweethaven02.com/MechTech...01/fig0658.gif
Push pull or liquid recovery method involves pushing the vapor and pulling the liquid. When no more liquid is present in the circuit, then recover the vapor the normal way:
http://www.sweethaven02.com/MechTech...01/fig0657.gif
Have you thought about a custom cooler that cools the recovery cylinder very cold so refrigerant quickly migrates inside? In that case, connect the recovery unit (not running) as for vapor recovery but also have a liquid hose as with liquid recovery.
When the liquid recovery by cooling the cylinder has completed, close the liquid valve and start the recovery unit, keeping the cooler running.
The bucket of ice water was patented a while ago
It doesn't work in winter time for air cooled equipment. It works quite well in Siberia. When the ambient air is -60°C, the pipes inside the air conditioners are almost vacuum and the liquid is stored in the remote condenser.
Only ever had to worry about AC not food refrigeration. They would not know the AC was dead until summer.
I thought the ozone layer absorb all the lost refrigerant :D :D :D :D :D :D :D :D
Lrac
LRAC
Lrac
Now, now, don't start, you'll get a slapped wrist you know :p
ring brad at polar pumps [look on there website] hire one of there machines, from a little puffer [pardon the punn] to a gas driven monster.
[quote=captaincool;58580 I have heard of the push-pull method, not sure what it entails, if someone could enlighten me would be most grateful. Any help appreciated. Cheers.:confused:[/quote]
Push Pull is an effective method for recovery but modern reclaim units that can pull liquid or vapour will save you all the hassel.
Cheers taz.
