Hi all could any one help regarding the above the chiller keep s coming up with starter gaurd alarm,
The chiller cycles alot due to poor load, i think this is a antirecycle protection is this correct???
thanks
mariobros
thanks
mariobros
Can't find any reference to 'Starter Guard' in the manuals, what is the alarm code?
Manual here if you want one....
http://eto.carrier.com/lit.asp
select 30HG and 'all'
Check your cc heater
did you do any mesurments at all ???
presure - temps - time - etc.ect.. ?
Ice
Are we going to hear from him again ? ;)
as mentioned before check your oil heater .the start guard monitores this
if all else failes switch a startguard card from a near compressor .to verify its operation and if needed buy a new one it is not that expensive
in order to reset a start guard .u need to turn off the power supply to the start guard
this is only if u messured your currents and compressor parameters and found all ok
I doubt it, just another 1 post wonder
crank heater or sensor fault
Thanks all sorry for no reply dont get on here much got some good info from link posted
Have a good week all
