Re: Freezer/Cooler Question
It does depend on the gas.
Because when it is used as a freezer, the gas will be coming back to the compressor to help cool down the head. So it might not be a good idea. Try and find out what the gas is. I think it will be on R404a.
Yes. The spec sheet says it is R404a:confused: .
If it is R404a gas, then it will have sufficient ref mass flow to cool compressor head. However, is the condenser sufficiently large enough to cater for mid temp capacity?
May need to monitor high side pressure...
