Dear sir
Octopus send me a catalogue in Swedish. I can't understand it. I attached the technical data. Who can help to get it into English? thanks in advance!
best regards
LC
Dear sir
best regards
LC
It's only a small table. I'm not sure if there're any forum member from Sweden. I need the help urgently!
regards
LC
LC, Swedish is similar to Dutch and I will translate what I understand.
Hopes this helps already because it was urgent.
AI Profiler
Sakring: fuses
Elektrisk inkopping: electrical connection.
Kompressor: compressor
Kompressoreffekt: cooling capacity
Slagvolym: Displaced volume
Hogtse utgaende varme...: max outlet heat temperature.
Koldmediemangds Gasol (): Suppose this is Cold medium mix with gasoil (is this possible Lc?)
Bryttryck= burst pressure
Bryttemperatur = burst temeprature (?)
Dimensioner Ispinne: dimensions ..?
varmepumpsmodul= heating pump unit
Vikt= weight
Styrenhet= control unit
totalförbrukning= total consumption
If you need more, let me know.
LC, I' knew the product already but do you believe in its benefits compared to a GSHP where the medium is a lot warmer then the air?
Have you seen under New Technologies my post about the Zuba Dan of Mitsubishi?
Hi Peter
Thank you very much. I don't believe it's better than GSHP but I want to confirm if it's better than a normal air source heat pump for it's said a new technology:)
I've not heard that Zuba Dan of Mitsubishi. Any clues?
I am grateful for the kind help.
best regards
LC
As soon I have more info about this Zuba Dan, I will post it here.
Hi Lc_shi, this site might help you....
http://www.translation-guide.com/fre...anslations.htm
Keep it bookmarked for future use.
Chillin:) :)
OK,
Here you go......
:cool:
Thanks for all of you.
I really feel the warmth of friendship of the RE members:)
Wish I can do some help for you in the future.
best wishes
LC
If you still have a problem with translating something in swedish to english I can help you. By the way gasol is propane gas.
Jag är på semester v. 29-32 återkommer måndag vecka 33. Trevlig sommar Gunilla Brunnström
It seems that the new forum software doesn't count the first post of a new member.
It's a bit of a "freebie", that's all. ;)
