car engine oil in compressor used as vacuum pump for laser
Can the oil in a small refrigeration compressor be changed to regular car engine oil if the compressor will be used as a vacuum pump for a CO2 laser? A friend is asking me that because he wants to build a CO2 laser cutter for precision cutting plastic and etching metal. (He works at a computer store and he wants to add a "professional" case modding service.)
Re: car engine oil in compressor used as vacuum pump for laser
Marc
Pse confirm that we can use car engine oil in refrigeration
:eek: Turns into brown sludge in the compressor, fridge oil in cars makes them smoke well bit like james bond :D
I was told in college its all to do with the oil wax
Car engine oil will wreck the fridge compressoe , as Snowman says will become thick sludge , porridge......
I saw someone do it once, put it into a Prestcold Semi.........
Stopped the motor in its tracks.......
Compressor was wrecked
