Carrier Genesis R 70 trouble (video)
:) Hi
Best wishes for a happy New Year Brother
I have a truck Carrier Genesis R 70
The engine is running a little bit and then stops and issued a strong noise and a lot of black smoke But I note that the clutch works at the beginning ? Is not normal
There are no alarm in the Control Box !!
We have examined the battery and all Relay and fusible
I have checked the compressor and the engine manually, there is no problem everything spins running smoothly
This video
https://www.youtube.com/watch?v=LElS...ature=youtu.be
Re: Carrier Genesis R 70 trouble (video)
Looks like belt slip to me.
Yup Mr Brian :)
But in the normal state the engine is running first and then after 7 or 10 seconds and then works to clutch spins the compressor and alternator
Here are the opposite
Engine starts overload !!
Sorry about my bad English :(
Fuel filter there is one in the pump near tank,one near the engine try starting it on a heat cycle adjust temperature to +20
Hi :) #cadwaladr
I will try him tomorrow
Thanks brother
I will tell the results
Ok the engine does not like too much load,but it should start unloaded take care friend
cadwaladr
Hi Mr #cadwaladr :cool:
I change fuel filters
But still when you started running
Just the noise and black smoke and then stop !!
Try taking the belt off to compressor and see if it will run be careful only do this for a short time or engine will overheat
cadwaladr
Thenx brother #cadwaladr
I after remplacing feul filter and clean pump feul filter the ingine want to start normal but now i have Air in feul seystem how I can remove it ? :):D
There is a bleed screw on the injection pump on the side of it think it's a 12mm spanner size,it should bleed itself thru the return line
cadwaladr
Thenx To important information
god Bless you Brother :)
Glad to help take care because I care.
Sounds like the injector pump or injectors mate
I think he has it sorted fixed now?
Yeh
#Cadwalar thnx bro
Evrything work now
It's done :D
Great to know,thanks for getting back to us one day I may visit your country and look you up take care.
