• Google ..
  • Google Content
  • RE_Calendar
    September   2018
    Su Mo Tu We Th Fr Sa
    1
    2 3 4 5 6 7 8
    9 10 11 12 13 14 15
    16 17 18 19 20 21 22
    23 24 25 26 27 28 29
    30
  • Pumping Liquid Refrigerant- what will work?
    Hey Guys-
    So im working on a new project, and trying to pump liquid refrigerant(134A) with a Delta P of 375 PSI, up to 510 +- Flow rate will be between 14-18 GPM. I am having a difficult time tracking down a pump. At first thoughts, i was looking for a gear pump, but people advised me that would not be the best. I received a quote on a Regen turbine pump for 16K USD. That is way too much for this project. I know vane pumps are used regularly at lower pressures, but i believe that may be the best for my application, if one can accommodate high pressures.
    Any thoughts you may have are appreciated.
    Thanks,
    This article was originally published in forum thread: Pumping Liquid Refrigerant- what will work? started by dc_Death View original post
    Comments 11 Comments
    1. TonyViet's Avatar
      TonyViet -
    1. den052's Avatar
      den052 -
      Vane pumps can work at hydraulic pressures up to at least 3000psi that I know of. A power steering pump on a car is usually a vane pump. I used to test those at 3000psi, as the PS system pressure range is 500-3000psi.
    1. den052's Avatar
      den052 -
      Also don't know why a gear pump wouldn't do unless there is not enough lubrication in the 134A refrigerant. Are you pumping pure 134A, or mixed with oil?
    1. Aurel STDL's Avatar
      Aurel STDL -
      This is proposal organic rankine cycle with R134a as working fluid.The overlal efficiency is mostly affected by the pump efficiency. There is no available high efficient pump on the market to pump 0,01ml/h of R134a at pressure difference 9.55 bar.
      I would apreciate any suggestion regarding the pump with higher efficiency ratio at this scale.
      Microgenerationconcepts
      Aurel STDL -
      Small correction regarding pump performance. It should pump 0.01m3/h.
    1. bfrauenheim's Avatar
      bfrauenheim -
      Check out SERO Side Channel pumps. They offer flow rates and heads in the range that you require.
      Aurel STDL -
      Quote Originally Posted by bfrauenheim View Post
      Thanks for your recomendation, but they have to big flow rate.
      I am looking for a pump with 0,01 m3/h and to be able to reach 9,55bar pressure difference.
    1. shooter's Avatar
      shooter -
      10 liters /hour is very small, what is aplication?
      use small piston pump, when speed is reduced even gascompressor can be used.
      Aurel STDL -
      Quote Originally Posted by shooter View Post
      I have used a solenoid pump. It works on same principle as a piston, but with solenoid instead of motor. The disadvantage is its very low efficiency.
      Here is a description of the application.
      http://www.microgenerationconcepts.c...-cycle-concept
    1. zeotrope's Avatar
      zeotrope -
      getting such a pump is not so difficult, price is quite high ... try
      speck pumps www.speck-pumps.com
      sihi Halberg pumps www.sterlingsihi.com
      lederle hermetic www.hermetic-pumpen.com
      they all have pumps for 4m/h 10 bars ... but there are no cheap pumps for this purpose ...
      I used their pumps for commercial refrigeration with R134a
      greetings from Germany
    1. thel33tone's Avatar
      thel33tone -
      Greetings from USA, i have successfully created a sustainable liquid refrigerant pumping system that incorporates a sealed pump design. It is currently in use in a medium sized refrigeration system, in cool weather it saves an incredible amount of electric near 30% according to the amp-meter. It incorporates liquid injection pre-condensor, and a plc controlled pump combined modulated via pressure differential sensor data. It allows the head pressures to run near 70psig with NO flash gas present. If anyone serious is interested in partnering with me contact me and i will show you what progress has been accomplished. Not to sound bigheaded but for purpose of explanation I have basically done what Hysave could not do in a cost effective more applicable way.
  • Recent Forum Posts
    TrickyRikki
    Apps/Software
    Evening all,
    Just wondering what people are using for the job sheets.
    Are you still using hand written paperwork sheets
    TrickyRikki 18-09-2018, 08:56 PM Go to last post
    A.King
    Re: Ammonia CA Store Complex
    Hi Gents
    Thanks for the replies.
    The oil that has been in use is an ISO68, this has not changed and is still in use. There are
    A.King 17-09-2018, 07:43 AM Go to last post
    Tayters
    Re: LG multi
    Compressor not pumping?
    Tayters 16-09-2018, 06:59 AM Go to last post
    eurocooling
    LG multi
    I have a LG multi about 9 years old 3 indoor come on pressure on cooling is 12 bar also it will not pump down can any one help as I do not work on these
    eurocooling 16-09-2018, 03:46 AM Go to last post
    malik55
    Re: Cause of unit requiring reset
    Looks this is an inverter type unit, may be same as KAY52DN7.
    Please note that A.C units are designed to work for human beings and normally should
    malik55 15-09-2018, 09:25 PM Go to last post
